The very first caveat one encounters with floating-point calculations is that decimal contants might not be represented exactly.
The following short code illustrates this issue.
#pragma JessieFloatModel(strict) //@ ensures \result == 7.0; double test1() { return 2.0 * 3.5; } //@ ensures \result == 0.100000001490116119384765625; float test2() { return 0.1f; }
This is proved entirely by the Jessie plugin of the Frama-C environement, thanks to the use of the Gappa prover as back-end. Other SMT solvers are proving part of the verification conditions, but not the ones involving floating-point rounding.
